Its going to be more valuable after "seasoning", which means getting rot and fungus after sitting there for two years.That tree is highly valuable. Everyone on the planet knows that.
It ain't black walnut!That tree is highly valuable. Everyone on the planet knows that.
But then in his description he states it’s uncut.But that maple is cutted.
Cutted maple is worth more.
We see those ads here, too. I never have time to answer any, to see how reasonable the poster is, since I seem to have enough friends and coworkers always asking me for the same. My deal is simple, and no one ever turns it down:We get a lot of "you cut it, you can gave the wood" ads around here. Then they go on to say you have to have insurance and you have to haul the brush away and grind the stump, etc... I always tell them I can cut it and remove the large wood for $100, but have never had a bite.
When I was just getting started, and needed more wood than I had, I would occasionally ask a homeowner about a tree that had been cut up and left in their yard. Almost every one of them would claim they were going to use it, or had a family member who wanted it. But then I'd almost invariably see that wood still sitting and rotting in the same pile for the next 1 - 3 years.I don't sit around when I find wood on the ground. That stuff gets hauled home ASAP.
I still ask about that stuff, and I still get the same answer, and it still sits there. I have even gone back a year later and they insist that it will get used....When I was just getting started, and needed more wood than I had, I would occasionally ask a homeowner about a tree that had been cut up and left in their yard. Almost every one of them would claim they were going to use it, or had a family member who wanted it. But then I'd almost invariably see that wood still sitting and rotting in the same pile for the next 1 - 3 years.![]()
I set mine on the ground because I don't have any way to move them. I picked up a 10 ton running gear and a hoist this fall, I just have to put them together so I can move and stack logs. I also have collected parts for a nice log arch. 😁If things don't thin out soon, I'm going to have to come up with some better log storage, as I'm having issues with rot setting in before I get to process them. I stack them on sleepers, but by the time you have a 6' high pile of twenty to fifty 15-foot logs, the weight is so much that the sleepers just end up buried and the bottom row ends up in the mud. Also, they don't dry well, the pile holds leaves and moisture, overall not a great situation.
Top covering would be worse, I think, without some way to keep ground moisture from being trapped under said top cover. The obvious solution is to just stop bringing home more than I have room to split and stack, but like you... I have trouble saying "no".![]()
Nice! Post pics when you get it together. I'd like to see it.I set mine on the ground because I don't have any way to move them. I picked up a 10 ton running gear and a hoist this fall, I just have to put them together so I can move and stack logs. I also have collected parts for a nice log arch. 😁
This is a yard where the city of Milwaukee drops off their street trees they cut. There is a saw mill there. They have plenty of ash, but need to truck in oak from northern Wisconsin. There are probably thousands of logs, on 5acres or more. These they get free, so definately not interested in purchasing any.City is always taking down trees in our neighborhood. Lots of old Maples that are rounding that 100+ year range. They usually take down the trees cut them up into 3'-4' sections and wait for someone like myself to come haul it off. I felt bad the other day I was loading the last of the tree up they had cut and some young kid in a pickup that had just rented a uhaul trailer showed up to snag it. Felt bad, but not that bad. I think he got the next one a couple days later.
![[Hearth.com] What happened to free wood? Laugh of the day. [Hearth.com] What happened to free wood? Laugh of the day.](https://www.hearth.com/talk/data/attachments/311/311129-d731e12fe31f4118319f3029ca6ab7a7.jpg?hash=nTqxSpw-Dg)
