Hi Everyone,
Recently score a great deal on a gently used Jotul F100 wood stove, and I am now in the market for a liner to run up my chimney, a piece of double walled pipe to run a few feet from the back of the stove to the liner, and a few heat shields for the top and sides of my mantel to meet clearances (see picture attached).
I see liners come up on craigslist from time to time (where I got the F100), often never been used, and I want to make sure I know what I should look for in purchasing a liner (as well as the double walled pipe and heat shields) whether I get it new or on craigslist.
Here's what I'm thinking and wondering:
1) I see multiple kinds of flex liners that say their good for wood stoves - what is the best for safety and performance? Do different companies vary in quality, or is it all the same assuming they have the same specs/kind of material, etc.? If I do buy used, is there a way I can confirm quality, company, material, etc? Do they have stamps on them...?
2) I am putting this liner up my three story unlined brick chimney built around 1900. What is the best, and safest way to accurately measure the chimney to know exactly what length I need? How can I make sure that the 6 inch liner (perhaps with insulation) will be able to get al the way through my chimney without running into any problems before buying a full liner?
3) My chimney is technically within the envelope of my house, except for the last 8 feet or so (perhaps less), however it's in an uninsulated area just on the inside of the outside wall, with only a wood wall keeping it within the envelope (and I live in Boston, so cold winters). I've read different thoughts on insulated vs. uninsulated (again, my chimney is over 100 year old and completely unlined), but I'm not sure what is best. I want to do the safest thing, even if that's more expensive. Should I go insulated or uninsulated? If insulated, is it better to use an insulation blanket, a pre-insulated liner, something else?
Are there other things I should be considering? Again, I plan on connecting this to a few feet of double-walled pipe to go into the back of the Jotul F100. Any thoughts on the double walled pipe and/or mantel shield are also welcome, but my main concern right now is the liner.
Lastly, I am beginning to think about installing this myself (with a friend or two), so any thoughts on that is helpful too. Thanks!
