What causes the occaisional *POP* from burning wood?
wahoowad
1,687
Virginia
I've always assumed it is moisture rapidly expanding, or maybe a volatile spot of sap. Or maybe a juicy bug.
I just had a pop throw chunks up against the glass. So what is it?!?!??!?! ;)
You burning tulup wood by any chance!
Could be a number of things.
Different woods do different things , some pop , some snap , some throw sparks ........
I know when oxygen is introduced to a hot coal bed this will happen. Probably the expansion of the gasses in the coals.
Try bamboo for a more spectacular show! (Bring a fire extinguisher though, just in case). I assume its volatiles in the wood heating up till the pressure exceeds the strength of the wooden 'container'.
I always thought it was gum/resin/pitch pockets. Moisture might do it also, if well contained, but I know that even bone-dry mulberry or pine will pop. Indeed, mulberry coals will often pop when raked.
moisture turning into gas, building up within a "pocket" and then breaking the tinsel strength of the surrounding matter and "POP"
