I am trying to finalize a decision on which Hearthstone stove to get for our small strawbale house in Crested Butte, CO. There are descrepency in the sizes given for the various models between what is listed on HS website and the Chimney Sweep Web site (broken link removed). Can some help me figure the actual dimensions of just the tops of these three stoves?
Also can you tell me how we could reduce clearances for these stoves by adding a NSPA 2111 Heat Sheild to the combustible wall behind the stove (we have a parrell installation). According the HS manual you can reduce the clearance to 9" on the Phoenix (pg 11), and to 3" for the (pg 24) Homestead. But I am having trouble finding this info it for the Heritage can someone help me out here? Being able to get the stove as close to wall as allowed is important. Can anyone confirm my data and get me the reduction for the Heritage?
Regarding weights, can someone clarify these for me also because there are discrpeancies that seem to me pretty large? Doen't the weight affect how fast (or slow) the stove will heat up? Does these discepancies matter to us on a day to day basis?
Phoneix 400 HS webite (manual) 450 ChimneySweep
Homestead 360 HS webite (manual) 440 ChimneySweep
Heritage 475 HS webite (manual) 500 ChimneySweep
Now let me tell you a bit about our installation so you can help us decide:
1. The house is 1.5 stories total 850 sq ft (actual interior walls - not the footprint because we have 18" deep R50 strawbale walls),
2. Room to heat is approx. 350 - this includes kitchen, mudroom, living room (open floor plan).
3. Stove to be located in the living room next to the kitchen and stairwell leading to the up bed/bath (350sqft total for the stairwell and upper floor).
4. The stove is also located close to the back bed/bath so we are hoping to have pretty good heat distribution (we are also adding at least one register to get heat to the bedroom (over the livingroom),
5. According to BTU calcuator we need about 23,000 for the whole house - 13300 for the actual 350 sq ft room to heat.
6. Our climate - very cold, 9000 ft in Colorodo, gets to -35 a few times, often -20's and -teens. Winter lasts 6 months.
7. The house is new construction (6 years old) with an overall R value of 23.5 as calculated by our building department (needed 22 to qualify for the stove - don't know exactly how they figure this but was told that most homes new or old will not meet this requirement. As mentioned, we have a strawbale house which sits on a concrete slab which stove will sit directly on.
8. Stove pipe ?straight out the back then run about 25' as per codes (20' inside an insulated exterior chase - 5' exposed at the top). We are considering sending the pipe straight up inside the house to the ceiling of the LR (11') then straight through the roof of the LR to the outside and up past the ridge (14' or so). Using triplewalled insulated pipe ?right? To get the draft we need we should go straight up? Will going right outside then up give us good enough draft.
9. The stove should remain in use 24/7 because we come home for lunch in the winter and can stoke it. We hope to use it for the primary heat for the home and turn the infloor radiant gas heat down to maybe 40 degrees just in case? I wouldl like to be able to switch the gas heat off alltogether but hubby disagrees.
OK, so there it is! Ryan helped us a lot when I called McGuckins in Boulder. We have narrowed it down to a soapstone from HS - in good part because the Keystone Woodstock sticks out into the room too far. Can anyone confirm this for me?? We would consider this stove if we can get closer to the wall but based on my research we can't get it close enough so that it doesn't stick so far out into the room.
Also, does anyone have experience with the sit on top oven accessories sold through Chimney Sweep.com and why it they told me it doesn't fit on the Homestead but will fit on the Heritage and I assume the Phoenix? Anyone have experinece using one of these on a soapstone, I REALLY want to be able to use this oven to augment our gas kitchen stove.
Thank you in advance for responding to my request. We need to make a decision in the next few days.
Valerie
Valerie
