I posted here earlier asking for wood stove/clearance help and I was pointed in the Jotul F45 direction thanks to begreen. Now that I have that out of the way, I am looking for some help on how to properly vent it out of here. I am planning on having a local sheet metal company bend up some 20ga steel to "finish" the ceiling of the opening seen on the second picture. Would a guy utilize that sheet metal "ceiling" to accommodate some sort of adapter to go from flex to rigid? As of now I am planning on having the exhaust discharge horizontally a short distance and put a tee in. I figured that may make it easier for cleaning? Is that necessary?
On the second picture you'll notice a void from the ceiling. I was thinking of having said sheet metal company bend a "sleeve" to transition from "ceiling" to the inside of the clay tiles. Is that also necessary? From the top of the "ceiling" to the bottom of the clay tiles is 8". I will lay down some sort of tile where the carpet is in front of the hearth to accommodate the protection in front of the stove. Its all constructed with steel studs and mineral wool insulation. I plan on using durock and ceramic tile and/or some stone of sorts to finish it off. The closest combustibles are the wainscoting on each side of the bricks, the framing behind the wainscoting, and the ceiling joists. I am going to call the inspector after I install that sheet metal ceiling.
Is there anything that I might be missing in this installation? Such as my last post here any and all feedback, tips, words of encouragements & insults are welcomed. Thank you for your time. This has been a learning experience.
![2.jpg 2.jpg](https://www.hearth.com/talk/data/attachments/304/304129-eb603ab91fd808b5e2dd4176379a84b4.jpg)
![What adapters/fittings do I need to vent wood stove? What adapters/fittings do I need to vent wood stove?](https://www.hearth.com/talk/data/attachments/304/304128-66731ab92ec9dd9fa6fd4760d89da7ab.jpg)
