How much of a concern is burning wet wood or partially wet wood in a catalytic stove?
What is the problem?
Backwoods Savage said:Why would anyone want to burn wet wood in any stove? It simply should not be done in any type of stove and it definitely could ruin the cat.
Todd said:Wet wood in a cat stove can cause thermo shock and crack and crumble the cat. If you have no other choice but to burn less than seasoned wood, burn hot with the bypass open til the wood stops sizzling before engaging the cat. Also check your chimney regularly.
savageactor7 said:I dunno but perhaps Hiker means surface wetness on otherwise seasoned wood? If that's the case I've done that but I don't have a cat stove...and the wood burns well.
We refer to unseasoned wood as green, unseasoned etc but not wet....right?
Hiker said:Yes, thank you. It all becoming clear as mud.
sonnyinbc said:Hiker said:Yes, thank you. It all becoming clear as mud.
Sarcism aside, if I could have afforded the Princess Blaze King (cat). I would have bought it=nice long burns, controlable fire, and just a wonderful piece of work. Now, if I had sprung for it, I certainly would never even have used it this year if I didn`t have nice dry and seasoned wood to burn. Why ruin a good thing?? I believe it is one of the best cat stoves/inserts out there in the market place.
Maybe pm north of 60 for more info. Like his adress explains, it doesn`t get much colder there.
We are all here cause we want to be so we can help others , and also learn more oursleves.
By the way, that Princess, when I last costed it out was about 3k, not including liner etc.
Hiker said:sonnyinbc said:Hiker said:Yes, thank you. It all becoming clear as mud.
I agree they are great stoves - that is why I am considering it (or a Lopi Revere) even though it does not meet all our concerns. One of the big ones is that in the insert form you cannot put a kettle on it for humidity (my wife does not do well with our too dry winter climate) and you cannot cook if necessary.
My cost on the Princess would be about $2650 (U.S) without installation costs and with the fan.
sonnyinbc said:Hiker: got a propane BBQ? If so, buy the Princess, you will have the best of the best.
Hiker said:sonnyinbc said:Hiker: got a propane BBQ? If so, buy the Princess, you will have the best of the best.
I guess we could use it in a pinch. But I an not inclined to stand outside in a blizzard cooking. Actually a cold rain would be worse.
