Yeah, I should've known better. ![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
This happened yesterday. Was on solid ground for awhile there, pulling a cartload of rounds out of the woodlot. Must've run it into an old logging rut or something. She bogged down, turned the tires and stuck fast. Tried prying it out with a log, inserting logs under the tires. No soap. So I hiked back to the garage and got the comealong. Chained it to a tree, dumped the cart load and pulled the darn thing out.
The woodlot has been pigged up pretty much all year. I've been able to just recently get in there, avoiding the spongy areas. Or so I thought. Anyhow, I got 'er cleaned up with the pressure washer and heard a cold brew calling.
Today I was determined to make a better path where the ground isn't as bad. Am pulling partial loads in the cart to avoid getting stuck again. Once those ag tires start turning and you stop moving, that's all she wrote. It's bad out there, my friends.
Got a couple loads of gum out and split today. It's taking a bit longer but I'll take any progress over none at all.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
