Seems every season its something with this stove., Started out fine in oct and nov. As soon as we need it cause of dropping temps it acts up. We started out in early oct with a complete cleaning, Bricks out, blower fan cleaning the whole gamit. It worked great up until a month ago. The auger we put it in a few years ago already crapped, so I put another one in. Now it will fire up, lights all work as should....green..then goes to red ect but after a about 15 mins it just stops feeding pellets and fire goes out.
I checked the wire under the thermo, no broke wires , made sure its out enough in the pot.....i cleaned out all the holes in the sides of the pot. pot door is functioning as supposed too. 3 things ive noticed and this is why were here to ask the pros.
First , when it does ignite, it whoofs pretty hard....like a combution whoof! Sometimes it takes 2 or 3 pushes of the reset button to get it to fire up.
Secondly it doesnt always fire up unless i remove the vacuum tubing from the stove side and give it a suck, and then i can hear the switch open or close? not sure on that...but sometimes i need to do that. sometimes not. its weird. other times it starts fine but eventually like stated it goes out ill go to hit the restart and nothing happens and then i have to do the vacumm tubing deal again. ...definately not consistent tho.
Thirdly when it is running or starting up....i can feel a fairly decent blower breeze around the auger side of the stove when the side panel is open. Im nost sure if i ever noticed that before? just seems like a decent abount of air coming around from that area.
I have put a new vacuum switch in this stove not that long ago , I called cleveland controls who makes it and they said it highly doubtfull its bad already as they last for decades. Could i have a vaccum leak some where? My door gasket doesnt look horrible...not like some i see online. Basically its like it loses its prime so to speak.
any pro advice is welcome and appreciated. Ive thought about buying another stove but i have so much money in this one now...and the prices of used stoves is nuts. Id hate to start all over learning a nother brand ect....
