My gold 60 indirect DHW heater has a leak at the top near the air vent tapping. I cut away the foam insulation around the air vent and the entire area is very rusted. When I open the ball valves that isolate the heater, the entire area where I cut out the insulation fills up with water rapidly. I'm not sure how the outside got rusted - maybe there was a slow leak that i didn't notice and it caused rust on the outside then eventually developed into a full fledged leak.
I'd like to collect on my lifetime warranty, but the plumber who installed it is out of business. He is the same plumber who used non-o2 barrier pex for the baseboard supplies and didn't install an expansion tank downstream of the backflow preventer on the cold water supply, both of which are required per the manual and will probably void the warranty. So it looks like I'll be buying a superstor tomorrow for $1100 :^(
What could cause the tank to leak after only 2 years of service? Is it possible that a couple hundred feet of watts aqua pex in the system could allow enough oxygen in to rust out the tank? Could the lack of an expansion tank be the problem? (I do have a T&P;relief valve which has not been going off)
