We should have known better…. God: if I only insisted on that blockoff plate
  • Thread starter Thread starter elkimmeg
  • Start date Start date
E
elkimmeg
Guest
This is a reprint of the post I presented in June. By code it is required. I don't care what some installer or retailer tells you. Believing and putting your complete trust in them could make you dead wrong. Hearthnet would not exist if all went well. This is the one place where good advice code and safe installs are discussed.
Guy and his wife are sitting in the insurance office, negotiating the final payment settlement. I still remember those events in the early morning three weeks back. It happened so quickly. Sounded like a freight train was coming threw the house. Woke me up from a deep sleep. No sooner did the noise start when all the smoke alarms went off
The smoke was everywhere. Me and the misses, grabbed the cell phone and a couple of blankets and made our exit. The smoke was so thick by now; we could not see anything we had to feel our way out. The fire dept arrived to our home fully engulfed in smoke. They started breaking out all the windows then axing holes in the roof . The paramedics checked us out to see if we were ok. Finally the chief informed us everything was under control. And that we better make plans to find another place to stay. The smoke damage rendered the home uninhabitable. My wife asked if they found Rover, our 5 year old yellow Lab? The news was not good. Rover died instantly, when that first 2100-degree hot flash back blew out the bottom of the chimney. Rover too enjoyed the comfort and warmth of our wood stove; He would sleep right on the rug in front of it.
Flash back 7 years earlier. The installers seemed knowledgeable. I posted questions on Hearth.com One reply recommended that a damper block off plate was needed. No one ever went far enough to point out the blocker plate prevented flash back. Everybody was only concerned about preventing room air from escaping up the chimney. It was never explained that these bats are not a permanent solution. Condensation from normal humidity forms in the chimneys in the summer this moisture gets into the batts and causes them to sag. Once they sagged they no loner prevented the intrusion of room air. That cooled my uninsulated liner, to initiate and accelerate the formation of creosote. I remember the poster said it should be of ridged material and recommended at using 26 gage metal. They recommended using the full liner and all agreed the 316ti was the superior product. So why did it fail? I thought it was installed to prevent this from occurring? Unknown to all till the incident happened. The chimney had an offset. The installers had a hard time getting the liner threw the offset. They used excessive force and weaken the structural integrity of the liner.. The latest batch of wood could have been a bit dryer and with an offset, a natural shelf for creosote build up, disaster was imminent.
Back to the insurance office:. Here is your check for $50,000 to repair your home. You complain it’s not enough and produce your estimates. The agent is apologetic and explains his hands are tied and that the decision was not his. He then claims how he went to bat for you, to get you this much. Really it was the best he could possibly recover, for an un-permitted un- inspected installation that failed.
I did not take the time to explain the reasons of blocking off the damper, if I felt it un necessary. For those that put in batt insulation, I would not post that info and expose your shortcomings. I would be ashamed to admit I’m a cutting corners and advocating it is ok for others to follow suit. The installer this guy talked to , recommended this being an accepted, practice needs to get re-educated in a hurry. It’s installers like this, that guarantee my job security
bumping this to the top..found it while searching, think it should be read again.
the fire department broke out all your windows...
As a long time firefighter, that is just not an accepted practice!!! Axes to the roof!!! Unless the house had an actual fire in it, that too was VERY UNNECESSARY. Sounds like your local fire department doesn't have a clue. Thank God you had working smoke detectors. Your local fire department should educate themselves on how to properly evacuate smoke and salvage their "customer's" property. It's departments like that who give the fire service a black eye...
That part about Rover always gets to me!
Still an excellent article, even with the faults.
I've seen some corrugated "liners" that I wouldn't use in a camp. Don't buy junk that will tear and go to pieces from the stresses of installation. I wouldn't recommend anybody take one of those pieces of crap, and stick it in a chimney, connect it to an insert or a stove, and depend on it under the best of situations. Block-off plate or no block-off plate.
Rigid, double insulated, "zero clearance" through the straight section of the chimney, and an insulated piece of high quality flex through the offset.
Fire always goes looking for air, if the chimney is blocked above, or severely restricted, and the liner fails catastrophically, Rover's dead unless you've got one heck of a block-off plate in there.
The long and short of it is also, keep your pipes clean. Clean pipes don't make big chimney fires, and the insert or stove will work better anyway.
Which "code" requires a block-off plate?
My last reading was, "according to manufacturer's instructions per the manual", "at a minimum...."
I hear lots of people cite codes and laws daily. Just like to know where to look to read it for myself.
Sounds like a chimney fire occurred in the original chimney, outside of the liner... in addition to the liner "failure". I don't see pictures and wasn't there, so it's difficult to say with certainty, but it sure sounds like they had something go extremely, seriously, wrong with that installation and I am far from sold on it being a simple liner failure or chimney fire. Even with a chimney fire and a liner failure, unless the chimney is nearly plugged, it's still going to draft the heat and smoke out the top.
"Assume the worst, hope for the best."
Webmaster said:
The story was made up.....the product of a good imagination. The idea was just that folks should pay attention and do a good job.
