Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
The right side blower in my Jotul Rockland was dusty and the motor stopped working. I cleaned it with a brush and it runs sometimes or if I give it a start with a finger. What can I do to clean the fan? How about WD 40
Sounds like the bearing is dry. A little wd40 on the shaft might work for a short while but it may take getting oil into the felt if it's a sleeve bearing motor or replacing the bearing.
Yes, WD is a penetrating fluid. Any lubrication will be short term. Oil on the motor shaft may not penetrate the shaft seal. It needs to get to the bearing or bearing reservoir or felt. Some motors have an oil hole for this purpose, but more commonly I find I need to drill one in the location of the felt. Not sure about Jotul blower motor construction to know if it's a sleeve or ball bearing motor.
I had the fans out a year or so ago and I could not find oil holes that I recall. The bearings are sealed and good quality. I blew them off, gave them a thorough cleaning and lubricated as best I could with machine oil. Not sure how much oil gets to the innards of the bearings since they are sealed. Main thing is to keep them clean, free of ash and pet hair etc.
How about some marvel mystery Oil... I have a ton of that stuff, and wondered if it would be good as a lubricant... I've used it on ton's of stuff and it works like the cat's meow
