Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I may go look at a used Waterford pellet stove to put in my kitchen. I'm wondering if anyone knows if these are still supported with parts. Its supposedly in good working condition........... somewhere around 7 yrs old? What might you pay for it?
I have a Waterford emerald and most parts are universal. Components such as the conbustion blower and snap switches are commonly used parts on many stoves. Other parts such as the control board aren't available. My stove works quite well, but I have done some tinkering to it. I have about $400 invested.
I have one, and it runs fine. The only caution I would add is that you may want to seal all the seams on the pellet bin. I bought one years ago, and my wife kept complaining about having trouble breathing every time I ran it.
I've since figured out two things.
One, the pellets we were using had a high level of tamarac in the mix, (she's allergic to them,) and
Two, I kept finding some sawdust inside the stove where the fans and the electronics stuff are located.
I took apart the stove and discovered all the sheet metal seams were pop-riveted together, with small gaps between the rivet points. That was allowing sawdust to fall down into the area where the fresh air was drawn in by the convection fan, and spread all over the house!
Applying RTV to all the hopper seams and re-assembling the 'back end' using RTV to seal anywhere that sawdust could get out seems to have cured the problem.
this is a stove i am thinking about buying...so might you have a place to price parts so i can determine what it might cost to fix so I how much I am willing to offer.
thanks I appreciate your help but unless I can tally the project parts cost,dunno if i should by the stove....it might be an easy fix,it might not...do I take the gamble...your opinion is welcome,and wouldnt place blame on ya
Actually the main concern I'd have is that some parts may not be available for that stove. In particular the mention of no available control board by a prior poster in this thread. The common parts usually have equivalents that can be substituted for the original parts. I suppose if you get good enough at cobbling together things even that wouldn't present a real problem, just be aware that any certifications might no longer apply.
ok so alil more info,seller said stove is about yrs old.worked until april... now what happened in april I have no idea.whats the likelihood it is the ecu?
ok so alil more info,seller said stove is about 10yrs old.worked until april of 09... now what happened in april I have no idea.whats the likelihood it is the ecu?
I just fixed a Waterford. She said the auger turned less and less and just would not feed pellets anymore. I checked the snap discs and vacuum switch and they were fine. No hopper switch. There is a door switch for the burn chamber door so it must be closed for the auger to turn. That was working fine. I put the test cord on the auger motor after removing the back panel and aha! It turned a tiny bit and died! Auger motor does not look good so I pulled it out of the stove and tested it with no load. Again it was not turning but if I also put my fingers on the shaft and helped it turn it did turn. Aha Stripped gears! So then I checked if the auger turned freely and it did not! They left pellets in all summer and the auger was jammed! I had to remove the auger backing plate and turn the auger by hand to back out all the pellets and vacuum them out! Then I could move the auger forward and it turned freely! So I checked the direction of the way the auger turned and aha it was opposite direction of my 1 RPM replacement auger motor. My replacement motor is reversible so I reversed it to match it up. Then I put it all back together and it worked! ! !
This stove was very old but very well cared for and very clean. I suspect it is very likely that you may have the same problem!
