so i bought a wood stove recently and the flue pipe came in sections that fit into one another.
At the Joints water is leaking on the outside of the pipe as seen in the crappy flip phone picture i took.
I'm here hoping someone here can tell me how to seal the flue pipe joints properly and what products I need to do the job.
I got the idea to use exhaust pipe clamps on it to seal it but I'm not sure if that would work against water leakage
I also thought of using that exhaust wrap that fixes exhaust leaks on cars but I'm also unsure if that would work.
this is my first wood stove and I'm learning everything as i go.
Currently the water you see leaking through in the picture is condensation as the top of the pipe is covered since the stove is not yet in use.
If someone could give me the correct kind of help i need It would be so greatly appreciated.
Thank you all for your time.
![water leaking through woodstove flue pipe joints. How do I seal it so water doesnt leak through anymore. Any Help is appreciated. water leaking through woodstove flue pipe joints. How do I seal it so water doesnt leak through anymore. Any Help is appreciated.](https://www.hearth.com/talk/data/attachments/320/320251-808460b57785a6cd0d1eb557d74f70fe.jpg)
