I finally got one out. We had been wanting to change the anode on our old water heater for years. The tank finally rusted through - because I didn't get the anode changed, and I have a new water heater going in. But I also had a test mule.
I have been reading up, mostly on internet forums like this one. In general new water heater anodes are driven in to near the max torque the fitting will take, and have a life expectancy of 6-24 months, depending on your local water. Once you get a new one broken out, get a thin layer of antisieze in the threads, then the pipe dope, and tighten it down as tight as you can get it with an 18" handle. Should be fine, and will be replaceable.
There remains the problem of getting the super tight from the factory one out. If you have it, you can try an impact driver or an impact wrench. Mostly likely the head is 17/16 inch, or 1 1/16 inches. 27mm is a bit loose, but potentially usable, you wont be putting it back in this hard. FWIW 27mm is 0.012" greater than 17/16, on paper. In practice, on both my old and new water heaters, my NAPA 17/16 socket was too small, my Kobalt brand (team blue) 17/16 socket was just right, and my Husky brand (team orange) 27mm impact socket was a hair loose.
I was really hoping to have a wife approved reason to bring in an impact tool, but I got both anodes out the old fashioned way. I used a thing named an Anita clamp, after my mom, who came up with the idea for changing tires on a boat trailer. Start with a 2x4. Drill two holes, near the middle, 12 inches apart, on the wide face. Stick eyebolts in there, use fender washers. Set the 2x4 on the ground, eyes up, lay the water heater or trailer tire in between the eyes. Grab a ratcheting tow strap, any color, hook into both eyes, wrap it over the top, and crank it down until something starts to complain. On a water heater, make some pencil marks where the top cover meets the side cover to make sure you don't twist the top case off. Using a half inch breaker bar and a 30" cheater pipe, total lever around 40-45 inches, stand on the 2x4 with the cheater bar on your shoulder and use your big muscles to get 'er done.
The vast majority - but not all - domestic hot water heaters use an anode with 3/4"NPT threads and a 17/16 hex head. 1 1/16 hex head, same thing. Replacement anodes are about $30 on amazon. Local, neither team orange, team blue or two plumbing supply places carry anodes at all. New water heater, electric, local, $500. Local, having a plumber replace the water heater I provide, $500. I can buy a LOT of $30 anodes for a grand. Life expectancy on anodes is 6-24 months, after that my tank starts rusting. I have a chore to do in November six months from now.
![water heater anode school water heater anode school](https://www.hearth.com/talk/data/attachments/295/295776-523ff1799b9e4e98fcd4bacff0cfa318.jpg)
