Hi new member here with a few questions. I recently purchased my first pellet stove. It`s a 2`nd hand stove a Warnok Hersey Profile 20 bought off Craig`s list so I don`t know much about it, mechanically everything seems to be working fine but the burn pot builds up clinkers and overflows the pot. I need to clean out the stove everyday and empty burn pot after using just 1 bag is this normal? Seems to me I should be able to go a bit longer than that. I have searched old posts here and found some usefull info, but was wondering if anyone can offer some more help.
As far as maintenence for this stove goes it looks like there was little or none at all done by the previous owner.This is what I have done so far,gave it a good general cleaning when I bought it and yesterday I removed the exhaust blower after reading up on an older post here, shoved my flue brushes in there as far as I could get and sucked out a ton of crap with a shop vac. I even blew compressed air thru the passages on either side of the heat exchanger and blew out even more soot & crud. I didn`t notice any improvement after this but it sure did need to be done.The gasket around the door also seems like a good snug fit. I make sure the ash pan is closed all the way as well before use.
I think the pellets fill the pot too fast the auger drops a few pellets approximatly every 4 seconds or so can I adjust this? If so how? Another issue I have is when I look online at the manuel it shows a rod to adjust combustion air,either I don`t have this or I can`t find it. So if there is no damper how can I adjust the combustion air? I think my stove is an earlier model since it also doesn`t have the clean out ports located behind the fire brick.
Here are a few details about my stove:
No t-stat installed, I just fill it up and turn it on in the morning let it run and shut it down around noon for a few hours untill the sun sets and temps drop then turn it on again. I let it run all night untill morning when I check on it again. My stove is located in an unfinished basement the flue is 3 inch and comes off stove with a tee and cleanout with 6 ft vertical rise to a 90 degree elbow and a foot of straight out to a sidewall type of wall cap. Flue pipe is all brand new been in use about a month now.
The pellets I use are New England Wood Pellet brand. I did use about a dozen or so bags of the Green Supreme`s from Lowe`s I didn`t notice a difference with either one.
Would drilling a few extra holes in the burn pot help to reduce clinkers?
Last question, does the fire brick serve any purpose other than being cosmetic I removed it cleaning my stove and didn`t bother to put it back.
Thanks in advance for any help!
Since my 2`nd hand stove is located in an unfinished basement.I wasn`t looking for the prettiest girl at the dance just one that puts out!![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
