Hello all, Newbie here,
I have a Vermont Vigilant 1977 wood stove and am confused on wall protection. My stove has both the bottom and rear heat shields and I am installing the stove in a corner which brings me to the walls. The manual says 18" from combustible materials on the sides and I plan on building a heat shield wall with a 1" air gap. The wall will be constructed by cutting squares of Durock doubled up to give me an inch spacer and fastened to the sheet rock every 16" across and down then Durock attached to the them followed by 3/8" porcelain tile. My question is would I be able to lower the 18"s to say maybe 14"s? I talked to a local wood stove store about it and he said the stove still has to be 18"s even with the air gap. I though an air gap would allow to be closer to the wall. Would it help if I cut the sheet rock off the wall and replaced it with Durock or just fasten Durock to the sheet rock and keep it at 18"s. I do feel at ease with the 1" air gap. Any safe suggestions would be greatly appreciated. Thanks in advance.
