Wall Mounted Kindling Splitter Recommendations
PA Fire Bug
314
Blair County, PA
I use a hatchet to cut up scrap wood from the school woodshop for kindling. I am considering buying a wall mounted splitter like the one in the photo below to speed up the process. Any recommendations? There are several different brands on Amazon. I typically look for lower prices but I don't want to buy the cheapest and brake it the first time that I use it. Thanks.
[Hearth.com] Wall Mounted Kindling Splitter Recommendations
I have no experience with one of these, but have looked into them and concluded that my stick built home is not the right support for this.
I'd mount this on a 6x6 and not a doubled up 2x4 stud.next to a door.
And then I found that splitting rounds by hand gives me more kindling than I use.
Reactions: all night moe
I asked a guy i know that had one mounted on his wall how he liked it.
He tried it for a bit and went back to an axe.
Got it for his girlfriend, which is what i was considering as well
My thoughts are, if your hatchet ain't broke, don't fix it.
I use a carpenters axe and a cookie on the floor. 19'' handle with a 2 or 2 1/2lb head. I choke up un the head to get it started.
Makes kindlin faster than I can use it. I usually have more than enough splitter slag.
For years I've split 2X framing scraps with a hatchet. But now I use the log splitter. Much easier to get thin splits. When you get into some knots there's no stopping it. Much faster to.
Seems like the wall splitter gives up the speed and momentum of a hatchet / small axe. I like the Kindling Cracker that was given to me OK. I might use it more if it were the larger one. That would cut down on jams when trying splits a little too big. Cut a few bins of old rough sawn 1 inch boards this fall. Went lickedy split with the hatchet. I like the powered log splitter best for making a range of kindling sizes from dry splits.
I split what kindling i need to start fires and make sure there is a box full if the GF has to start a fire for me.
Most is splitter trash, and any loose stragglers still hanging onto splits get pulled off and into the kindling box they go.
I have a pickup box with a canopy on it that is still over 3/4 full of Fir scrapes from building my house
Never a shortage of stuff to start fires with
