Vogelzang 5770
Frank w.
1
Ma
I have a vogelzang 5770 .it's displaying a E2..I've replaced the exhaust blower , both limit switches and the motherboard.also, the vacuum switch. Still a e2.ant ideas out there .ty Frank w
Dirty air path from the burn pot to the chimney cap. Weak exhaust blower motor and fan.
Make sure the hole in the lower right side of the firebox (that goes to the vacuum switch) isn't plugged up with ash.
Also make sure everything is cleaned out. The whole pipe. And the side ash traps, and the passages inside there. I run a flexible dryer lint brush through mine.
Do you have an outside air kit, or are you pulling air from the house?
