Vertical pipe through ceiling
klincker
36
Andover, NJ
So I am moving my stove from one location to another. It’s currently installed through an exterior wall and then vertical about 8’. Id like to put it in another location where it Would go vertical through the ceiling and then the roof. Can I use the wall thimble on the ceiling? I know I need flashing and storm collar. The wall thimble I have is a Selkirk piece. Is there anything else I would need?
https://www.google.com/search?q=sel..._AUIEigC&biw=414&bih=660#imgrc=cSXqLlj3X5OdbM:
Don't know if I would use a wall thimble
I would rather have a selkirk ceiling support
It is made to do the job and meet code
Going to need an attic insulation shield. I’d definitely use a tee with a cleanout to come off your stove. I use Duravent so I can’t help you with any part numbers for Selkirk.
I have a clean out that I will use. I just thought those boxes were for cathedral installs on a 45
You will need a ceiling box that is designed yo support things and meet code
Sent from my SM-G903W using Tapatalk
As zrock said you need a cathedral ceiling kit just like i used
  • Vertical pipe through ceiling
You don’t have to use a cathedral box. If your ceiling is flat, use a thimble, but definitely use a AIS. Plumbers strap in the attic will give you plenty of support.
I guess that’s a part of the equation not given yet. Are you going thru a flat ceiling 1st and then thru the roof or up thru a cathedral ceiling.
Flat ceiling and then roof. Distance from ceiling to roof is not much. Hopefully the AIS will fit.
