Last week the dealer came and changed the versa grate motor in the york insert here. Tonite while I had it apart cleaning I notice that there's a space between the versa grate and the burn pot...enough so that if you throw pellets in the pot that some could spill out under the burn pot into the ash pan. So I'm looking at it and the fact that the versa grate could flop back and forth on both sides quite a bit. I thought it odd it did this, I never remembered it being this loose before. Then I notice 2 screws on the bushing coming out the back wall that runs it, and they looked adjustable. The burn pot has two little ears that stick down and look like the grate is supposed to ride back and forth at that level. I readjusted this up (took a few tries because you have to take everything out to loosen/tighten the screws) and it's not tight tight now but the clearance is much closer than it was before and nothing can fall through now..
Is this correct on how it's supposed to sit under the burn pot? Is it supposed to be adjusted up til it rides against the bottom of the burn pot?
All but 3 holes in the versa grate were plugged with ash... one day. I'm wondering if this versagrate clearance issue is/was part of my problem?
