I have an old (but new to me) Vermont Castings SDV30 (serial number 7224) NG stove that I don't seem to be able to vent correctly--my assumption it is a venting issue not a parts issue. I get a solid pilot flame and the stove lights well, but after anywhere from 45 seconds to a couple of minutes (usually closer to the 45 second mark) the pilot flame is "drafted away" from the thermocouple until that side of the 3 way pilot assembly no longer has a flame and doesn't cover the thermocouple anymore...and then the main and pilot shut off. It seems to get wispy or thinner as well and sometimes wafts away before relighting on the 3rd axis that hits the thermocouple--the other two seem to keep a strong flame though they draft towards the front glass side. If I barely crack open the top of the glass, the pilot remains strong over the thermocouple and the stove stays lit. I'm using duravent 4" inner 6 5/8" outer and have 24" rise to a 90 degree before a 3' horizontal run to a duravent horizontal termination cap (46DVA-HC). Really getting frustrated because the are so few seams. I used a black fireplace and stove repair sealant at the exhaust collar at the top of the stove (dries hard) per the installation guide and high temp RTV (600 degree) red sealant for the inner and outer seams of the pipe and the terminal cap. Open to ideas or troubleshooting steps. Pictures of the pilot with the stove off and then with the stove on as it goes out. Thanks in advance for any help...at my wits end. Phil
![[Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off [Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off](https://www.hearth.com/talk/data/attachments/282/282407-3d48215479490ba166aae36c9f40251d.jpg?hash=wg1s_KXCzh)
![[Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off [Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off](https://www.hearth.com/talk/data/attachments/282/282408-8f0db51675b172c285ab805e9241161f.jpg?hash=fvtBsahi1Y)
![[Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off [Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off](https://www.hearth.com/talk/data/attachments/282/282409-7e2c90418896955b4bf028cb1fd2fc11.jpg?hash=Vf3iLfTFrf)
![[Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off [Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off](https://www.hearth.com/talk/data/attachments/282/282432-7b3ef903cae60db7d584c846b8a7b169.jpg?hash=clQ0F8kodY)
![[Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off [Hearth.com] Vermont Castings SDV30 NG Problem...pilot on, stove on, then pilot off the thermocouple and all off](https://www.hearth.com/talk/data/attachments/282/282461-09923092bbc7811aa1e9c29468900a67.jpg?hash=g4C1a5oEQ4)
