I have a VC Resolute.. Not Acclaim.
I found my old post on this site, which was a copy and paste of somebody else:
www.hearth.com
My door gasket is finally shot after 6 years+ of "new to me". It's literally falling apart.. Not causing any major issues yet, but it is also not that cold yet (and this is our 2nry heat), but I do smell smoke every once in a while.
Based on the quote above, 5/16 or 1/4 will do.
Can somebody recommend where to get the fancy stuff for the griddle?
All the kits I have found online are for Acclaim (and not Resolute I)..
VC resolute gasket question
I replaced my gaskets before our cold season started. The doors weren't as tight as they were with the old gaskets. But it didn't smoke. I bought new gaskets just in case I wanted to replace them to create tighter fit. When a fire is really hot, I can see a slight glow from around the edge (like...
www.hearth.com
5/16" for door. The griddle depends: If it's a "raised griddle", that is it doesn't sit flush w/ the top, then use the same 5/16". If it's a flush griddle, then get the fancy 5/16" armorseal stuff with the meatal wound around it. Armorseal doesn't work w/ raised griddle, but standard gasketing can work w/ flush graiddles. Just deosn't last as long. Is there glass? Use 5/8 or 3/4 adhesive tape. With the cast panel, 1/4" regular rope works fine. Careful removing old stuff, (asbestos)
