I cleaned my chimney today for the first time since I installed my used VC Reliant (with a top draft). When I went to clean out the stove, I wasn't sure if I was actually getting all of the soot and creosote or it if was going back behind a steel (or probably cast iron) plate that has a row of 1/4-inch holes in it (see picture). I'm wondering if those holes which now appear to be blocked are necessary for the draft. There was a bolt (5/16, i think) dead center on the back of the inside of the stove right below where it says 1988 (see picture). I tried to remove that bolt, thinking it would give me access to clean out the area behind those plates, but nothing moved. after I took out the bolt (which might actually have just broken off, since now I can't put it back in. Along the way, reaching up behind the metal plates at the back of the stove, I out some broken pieces of some kind of white material. Maybe it's firebrick, but it's whiter, thinner, and more crumbly that the firebrick I'm used to.
Can anyone with more experience with these stoves give me any advice?
Don
![[Hearth.com] Vermont Castings Reliant cleaning question [Hearth.com] Vermont Castings Reliant cleaning question](https://www.hearth.com/talk/data/attachments/299/299394-33b9178b6d67b31a02b5e3b8dcbc861f.jpg?hash=xpTmNUxmTU)
- what is that white stuff, and do I need to replace it?
- can I / should I remove any of the pieces from the back of the stove to clean out ashes and creosote crumbs?
- Is that bolt I removed (and can't replace) critical for anything? (nothing moves that didn't move before I removed the bolt)
Don
