I have used my new VC Defiant since late Nov and i am still amazed at the creosote buildup! I reported earlier on this and your suggestions were helpful and utilized. Now, i have used seasoned wood, more than a yr old, and burned the fire at about 450, except during the night when I leave it burning all night. As reported earlier, i have been burning a franklin stove and a Country Flame insert for about 25 yrs without the creosote buildup!
Now there is a lot of creosote, it is however the soft stuff, rather than the hard. And, the buildup on the chimney cap is now easily scraped off, before i had to use oven cleaner and other cleaning solutions. In the past i was cleaning the chimney once a yr. I have already cleaned the VC chimney twice
Do i need to burn at 500+ (that's with the thermometer on the griddle)?????? YOUR INPUTS/RECOMMENDATIONS APPRECIATED!!
Additionally, the ceramic in the stove has cracked. i cleaned the stove with my shop vac and found the right side stove brick (vertical one) is cracked. I just don't see how this could happen if the brick is made of the correct materials!! YOUR INPUTS/HELP PLEASE!!
THANKS!
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
THANKS!
