I have a Vermont casting encore 2n1 flexburn, I’m running it without the cat as I can’t get them to last more than a season (they melt pretty bad, even though I installed an Auber AT100 with a cat temp probe and I never let it go over 1500F), and I’m burning kiln dried hardwood (mostly oak) which measures <8% moisture content.
I previously had a cracked fireback and fire top and got new ones under warranty from VC, which I fitted myself and did a full rebuild with new gaskets everywhere. I’ve tested and can’t find any obvious air leaks, today I pulled the stove out remove the flue collar and fitted a new 30002422 3/8” fiberglass gasket, took the bottom off the T and gave the chimney pipe a good bash. There was little to no creosote in the bottom of the T, and I looked up the chimney and it looked visibly clear (I did not sweep it, it was last swept at the end of last season and I’ve put almost 4 cords through it this season). The chimney is a very tall brick chimney (40ft and change) with a steel flex pipe liner, Un-insulated currently. The stove is 5 seasons old.
My problem is if I run the stove with the damper open I immediately get the roaring air sound and the T and the flex pipe goes dull to cherry red (700+F). If I close the damper the roar goes away immediately and the pipe returns to a sensible temp. The stove isn’t even that hot when it does this, it can happen with griddle temps in the 4-500F range. It really looks like a chimney fire, but I can turn it on and off with the damper, and surely if it was a chimney fire it would have burnt away the creosote by now? I visually inspected the chimney cap and there are no visible flames or sparks coming out when the T is cherry red.
I can also crank the air down to minimum with the damper closed and get an all night burn without any issues, I load it up about 9-10pm and I still have plenty of coals at 7am for it to relight easily just by putting new wood in.
So….what am I doing wrong? Is it some air leak I haven’t found? Is my wood too dry? (Is that possible?). Should I invest in a higher quality insulated liner?
We love the stove’s heat, but damn this thing is high maintenance, I’m kind of tired of babysitting it and I’m afraid to let my wife run it by herself when I’m away. If it wasn’t for the cherry red chimney and the roaring air id think it was running great.
The picture attached are from a burn I just did now, within 10-15mins of starting it with the damper open I got the red stove pipe, I then closed the damper and it went away, re-opened the damper and red pipe again. Included infrared thermometer pics are all from when the pipe was glowing. I closed the damper even though the stove wasn’t very hot and the temp in the cat area shot up but isn’t crazy, as shown by the Auber pic. I then turned the air down to minimum and it’s calmed down and seems to be in cruise mode, 600F griddle top currently which I find will drop to about a stable 450F after an hour or so, with most the flames gone, which is the second pic of the fire.
Appreciate any advice!
![B50A8142-9D07-48F6-BF30-716F7CA1935A.jpeg B50A8142-9D07-48F6-BF30-716F7CA1935A.jpeg](https://www.hearth.com/talk/data/attachments/292/292790-6ba24c7333e19548ae40fc88339e66cb.jpg)
![CF868D24-9EF5-482E-94FE-7256AB48A987.jpeg CF868D24-9EF5-482E-94FE-7256AB48A987.jpeg](https://www.hearth.com/talk/data/attachments/292/292783-1888492ff3905aea614f6d1596eb3ba6.jpg)
![3A40DA78-9247-4EA9-A55B-D146B08771F7.jpeg 3A40DA78-9247-4EA9-A55B-D146B08771F7.jpeg](https://www.hearth.com/talk/data/attachments/292/292784-86cc925749bfd900a000a7dc15294eaa.jpg)
![5069E8C9-F4D5-4834-A7B7-84564444A904.jpeg 5069E8C9-F4D5-4834-A7B7-84564444A904.jpeg](https://www.hearth.com/talk/data/attachments/292/292785-29b877469b33c25429185038f0f26e89.jpg)
![557CE266-E1E1-4680-B93B-7BCE6CE65231.jpeg 557CE266-E1E1-4680-B93B-7BCE6CE65231.jpeg](https://www.hearth.com/talk/data/attachments/292/292786-51321d2d243ea27b99b323a880fd5774.jpg)
![3A507D1B-95F7-422B-BF3F-4C9CC808E518.jpeg 3A507D1B-95F7-422B-BF3F-4C9CC808E518.jpeg](https://www.hearth.com/talk/data/attachments/292/292787-f816930727af30a16fafc9bd7a46a7e8.jpg)
![129C1F3D-2855-4995-A4C7-F29BC12E5012.jpeg 129C1F3D-2855-4995-A4C7-F29BC12E5012.jpeg](https://www.hearth.com/talk/data/attachments/292/292788-866dc3d6f3aabbfc99c994d390830ef8.jpg)
