- Oct 7, 2012
- 5
I need to replace the damper gasket on my LWM. I have a couple questions. Is it possible to do this gasket w/o taking the upper fireback out, by just opening the damper door and gluing it in? I have tried this with limited success. If so how do you keep the gaskets in place and not have them keep falling loose, during installation and curing? Is there any special adhesive or self adhesive gasket that anyone has used?
I know it is best to take the damper out but I'm a little nervous about breaking rusted bolts and lining up the damper with the control rod on reinstallation. Is it a tricky job?
Lastly we don't use the stove as much as in the past. What are thoughts of those on the forum about not replacing the gasket at all, especially from a safety standpoint? I know the stove won't work as well and be as air tight, but I'm using the fire now more as a decoration than heat.
