Thanks Coaly for the info. Also I want to refurbish the stove before I install it. I've done some reading up on the my stove. I do not install door gaskets correct ? The round stock is the door seal ? Also if I wanted to replace the door handle springs with new ones, would you recommend a brand and type ? Thanks again.Yes it is.
Unfortunately the original stainless steel door handle springs were replaced with newer plated springs and the feet didn't exist when it was built. It should come with a black fire screen instead of feet.
No, the early stoves had chrome balls that were adjustable with a set screw for uneven surface. Later the straight facing feet were made of cast iron finished with Black Oxide or chrome plated. Later they were plated with white brass. Even later they were cast angled with white metal (sometimes called pot metal which is not ferrous so is not magnetic) they were also plated with white brass. (yours) Your legs are also supposed to be tapered as per the original drawings but some fabricators did not taper, and cut them straight or an angled tip like yours. When angled properly, the feet don't fit and look right. The feet also came with washers to stack inside them to level stove. They are stove levelers, not just for looks. If yours doesn't have steel rod welded to the legs or nuts welded inside legs to screw threaded rod into, it never had the chrome ball feet. The owner probably saw them as an accessory years later at a Fisher Factory Showroom and added them to their stove. They were cheap selling for 2.50 black, 3.50 plated and now a mint set can sell for $50 to $100 EACH. You'll find people selling them in rough condition, or even painted asking for the same amount as new condition. Perhaps they don't know what new looked like.......
This is the time period correct screen;
View attachment 201257 They do show up on eBay from time to time, but be prepared to pay. They can go into the hundreds, as well as the feet. The feet OR screen can easily be worth more than the stove.
The '76 Grandpa pictured above is more of a prototype than the mass produced version. It has a 3 piece welded top, brass handles and brass ball feet. The doors were painted black with no highlighting.
