So I have a new ventis he200 installed and the fire seems to die no matter how I have it set for the flue. I have the handle pulled out and the fire seems to die, I push it in and it dies. What I'm the world am I doing wrong?
What is the moisture content of your wood? How long are you letting it burn before shutting it back? Are you leaving the door cracked a little to get it started? How tall is the chimney and what is the outside temp?
I just got it going, I think the wood is still a bit moist. I had it covered and moved some into the house a few days back but probably not long enough. I'm just trying to cure the fireplace before the season starts.
How long was it cut split and top covered before now? What you are describing could be caused by many issues but the most common are wet wood and or outside temps being to warm.
It was definitely wet. I grabbed a few pieces from my shed that I had been in their for a year and no issues. I think I will get a moisture meter just to have.
