Hello fellow burners!
I have learned a lot on here, and am loving my first full season of burning. I wanted to ask if anyone has any advice or similar experience before cutting a hole in my wall.
Would cutting a vent above the door between my kitchen and living/dinning/stove room help keep the kitchen significantly warmer? Please see the attached floor plan sketch.
Fan on the floor of the kitchen blowing into the stove room does work quite well. Without the fan, the kitchen gets cold regardless of what the stove is doing. My real question is would the vent above the door work well enough that we could forgo the fan, at least most of the time?
Complicating this is that the main celling height is 8’ while the kitchen addition is 7’. However, the proposed vent would be the lowest elevation that heat could escape the ‘heat lake’ effect of the stove room.
For reference, the house is old construction, 1700 sf two story, 8000 hdd climate, heated from the main floor with a smallish fully radiant stove. So far so good, obviously the real test is still coming.
![Vent over door for heat distribution Vent over door for heat distribution](https://www.hearth.com/talk/data/attachments/304/304264-9e4b8420ea2de9595b91fe3f923d3b63.jpg)
