I am waiting on my new wood insert to arrive in a few months. Backordered ! I am a DIY person on everything I possibly can my 60 years. I am gathering all the information I can on installing my SS Liner when it warms up in NC b4 the insert arrives. My fireplace is very large 32x47 at the front with a flue system the same. I will be able to remove the damper and push handle easily with no demolition. All bolted in. I can see all the way to the top easily when getting in the firebox. It looks like the liner is 10x10 at least. I have not been on the roof yet to confirm. Insert calls for a 6 inch liner. The damper gap is 6 and 1/8 clearance when removed. I could do a little grinding and gain another 1/4 inch without damaging the original damper setup.
Now for my problem...the top of my chimney is capped with as you can see in attached pictures. I do not think I can get the liner in from the top. Will a flexible one make that tight angle under the cap ? I am guessing it's around a 18 inch hole height.
With as much of a straight shot it is looking up the chimney, has anyone ever put a liner in from bottom up (backwards) ? It is 27 feet to the top. There is no way I am going to pull the cap off. Any help, direction, education would be much appreciated.
![Vent Liner question or problem? Vent Liner question or problem?](https://www.hearth.com/talk/data/attachments/292/292085-2f408b11b0a0b59eb148018b4f4afb90.jpg)
![Vent Liner question or problem? Vent Liner question or problem?](https://www.hearth.com/talk/data/attachments/292/292083-6751a978069cfa55affee5e237aa24f0.jpg)
![Vent Liner question or problem? Vent Liner question or problem?](https://www.hearth.com/talk/data/attachments/292/292084-fa75e9da76c23de51a7d971c22201979.jpg)
