Hi all,
It's been a while since I've been on this forum, but good to be back.
I've been heating our small, drafty NH modified schoolhouse for a few years with the old VC Vigilant that came with the place. The usual joys and complaints apply - cranks out the heat when you want it, but also when you don't, and eats a lot of wood. There are two current issues that make me think about modernizing: an imminent attic insulation project may make this beast too much stove for most of the year, and backpuffing has started to get out of control. I guess we'll just have to see what the insulation does, but I could use some advice on the backpuffing - my wife is getting freaked out by it.
The simplest explanation is that I too often stuff it and snuff it for the night too quickly, before the top of the load has adequately charred; my wood is fine (all hardwood), air vents are clean, and the 8" tile chimney is clean. When I simply give it more air for the night, though, I have no coals in the morning (actually, I have minimal coals no matter what I do). I'll work on my nighttime loading and air control habits, but the stove has several other issues that may be contributing to the problem. Would addressing any of these improve the situation?
1. Haven't done a thorough light test, but it's probably due a rebuild with new cement - it may never have been done and may be very leaky. Not relishing this idea. I replaced the door and griddle gaskets recently. What's the dollar bill test, by the way?
2. The one-piece fireback is cracked, though it's still intact.
3. The joint where the 8" double-wall pipe from the stove enters the chimney is just a simple single-wall male-to-male adapter, and I can hear air rushing into the joint when the draft is pulling hard (instead of pulling air through the stove, presumably). This joint, by the way, accumulates far more creosote than any other part of the system.
4. The oval-to-round adapter between stove and pipe is really just a short length of single-wall round that someone squashed into the needed shape. I can see light coming through where it stuffs into the stove. Assuming I should get the proper adapter, where can I find it?
So, while I know I should fix all this stuff, will it fix my nighttime backpuffing/no coals issue, OR should I just bite the bullet and upgrade to a modern stove that is right-sized for my soon-to-be insulated house?
Thanks, and happy burning.
