Having problems keeping my VC Resolute burning hot in the operating zone. Start off w/ the damper open and bring it up to ~500 degrees then put the damper in the down pointing direction, open the secondary air port 1/2 way then watch the temp drop to the 200's.
I *think* draft is ok since I can get it up to 500 w/o any problems with damper in open position. Over the summer I took off the firebacks and re-cemented the baffles and replaced all the gaskets. Have an newly installed(Dec-2007) insulated ss chimney liner.
Local VC dealer mentioned that my wood may be too wet, but doubt it. Either way will buy a few bags of bio-bricks tomorrow and eliminate that possibility.
One observation; the temp of the flue pipe is higher than the stove. Maybe that's just because it takes less time to heat up the ss pipe than the stove but I wonder if I need to add a damper plate just to inhibit the air flow a bit and give the heat a chance to heat the stove before going up the chimney.
Any suggestions?
-d
Any suggestions?
-d
