Thank you for the reply. I don't think my question was clear enough. I did find a couple of posts after my original post on this, but there were no answers. I have pictures that will hopefully explain this better.
The Resolute II apparently came in two models, one with glass and one without. I have the one with the blank plate (without glass), and Woodman's shows a schematic with glass.
Now for a few pics, and a few questions I need help with at the end of this post.
I found the next couple of pictures in this forum in another thread. Someone was rebuilding the same stove. That door has glass. Note that the glass is in two pieces, and the joint is where the blue tape is:
This is my door, with the blank plate installed:
So my question is, how do I replace my blank metal plate with glass?
Woodman's has the following parts for the glass door version of this door. Please refer to #48 and #49 below.
#48 (the glass) looks like this. Two pieces would be needed.
#49 is this frame, which seems to be the replacement for my blank plate:
I actually bought this piece of glass before I did more research. The description said it was for a single door Resolute. I did not work because the door is curved outward and the glass isn't.
Now for my questions:
1) If I bought glass frame #49 and glass #48 (and glass clips), is that all I need to convert the door to glass? Has anyone done this?
2) How are the two pieces of glass sealed where they meet?
3) Is that glass frame curved on one side to compensate for the curve/bulge in the door, and flat on the inner side to be able to mount the single piece of glass I have (the last pic above)?
Thank you!
