I recently moved to a house that has a Vermont Castings Intrepid II model 1990 wood burning stove. I discovered when operating the damper door lever it was not opening the door as it should. When I rotated the lever down the door stayed in the closed position and would only swing open when I manually pushed on the door itself. It closes just fine, but when try to open it it will always remain in the closed position.
1. Am I correct in my thinking that the door should just open when the lever is rotated down?
2. Do you think that something is broken or improperly assembled? And if so, is it probably that the the damper rod has slipped off of the damper D-plate or the damper D-plate itself is missing or broken? Or is this not the function of the damper rod to damper D plate interface and it is entirely something else?
Any help or guidance would be greatly appreciated.
Thank you, Phil
Thank you, Phil
