I have got a new Vc encore. It’s rear vented
It will sit out in room far enough to meet all clearances. I am building an all masonry surround( kind of alcove but not really. It will be 1 inch off studs in the back n it is built on block foundation all the way to the ground under house, it will be 8 inch block with fire brick on hearth pad and inner walls, and regular brick on outside. If it meets all clearance to combustibles as is and build the surrounds completely out of masonry do clearances from masonry matter. Stove will sit halfway in hole. I know this sounds complicated but it’s the look we are after.
![Vc encore masonry surround Vc encore masonry surround](https://www.hearth.com/talk/data/attachments/301/301791-4eb74b8d19c30a013b40eae0cd0777a9.jpg)
