Today it was 62 degrees and I let the stove go out so I could readjust the secondary flapper coil to see if I could get better control of the over firing. Two weeks ago I adjusted it from 4 o clock to 5 o clock position and it made things worse when the griddle temp was creeping past 650 and cat probe would sneak into 1800 ![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Today I adjusted it to 3 o clock position which had the flapper open 1/2 inch cold but it worked much better once griddle hit 500. I could close damper slow and cat probe went to 1250 and I was able to control secondary much better. The flapper closed all the way when cat probe hit 1300 and never reopened like it would at 4 o clock position
I will keep an eye on it for few days
