Greetings!
We had a chimney fire on Christmas day. So this has alerted us to the inefficiency of our current stove, a Federal Airtight 264CLL from 1981. After our repairs are completed on our liner we are wanting to replace the stove. Our fireplace opening is on the small side, along with a shallow hearth slab.
Firebox: 28 7/8" H
27 1/4" W (at the narrowest section due to stonework ) 28 1/2" at the widest
Hearth slab is 17 3/4" D
Chimney liner is a 6" SS insulated non-flex
We are an electric house. Our central heating/cooling system is a Heat Pump and electric furnace. Thankfully we've had a mild winter so far and its been able to keep up and maintain a comfortable temperature. It's a new unit, installed in 2019.
House size: 1555 Sq. Ft. (our current stove heats approximately 1200 sq ft. --being the entire 2nd floor bedrooms due to cathedral ceilings, and the living room, dining room, and kitchen of the first floor). It's a relatively open floor plan. Fireplace is on the west side of the house in the living room (cathedral ceilings to a loft hallway between 2 2nd floor bedrooms). It also heats into the dining/kitchen area due to open floor plan. 1 bedroom and bathroom on the east side of the house are separated by a hallway that usually doesn't get the heat. So we supplement with a space heater when its single digits outside. Otherwise, they maintain 60 degrees while the living room would be 75.
Obviously, our space is limited. We have considered demolishing the hearth and adding a floor-flush hearth that's extended a bit, this will open up our stove options. However, we love the look of this current fireplace and we are frugal people. So for now, we are thinking of retaining our current setup with a new stove.
This brings me to our options, which also happen to be limited. From going to a few dealers and doing in-person measurements, I believe we narrowed it down to 2 stoves: The Vermont Castings Dauntless and the Hearthstone Craftsburry 8392, both being new 2020 compliant models.
Originally we were leaning to the VC Dauntless. Wife and kids love the top load option, and the aesthetics. But I've been doing some reading and it appears that Vermont Castings has had issues in the past, and their current offerings may be improved, but not enough. I have some concerns about it being a "down draft" stove. And really my main concern is the ceramic refractory, or "secondary burn engine" as they call it. It sits in the back of the stove, and to me, it appears fragile. I don't want a stove I'm replacing parts on every 2 years because they keep breaking. Also, we would have to chip away a few firebricks from the fireplace fire box smoke shelf to move the chimney pipe back a few inches so that this stove will not sit completely under the fireplace. It is a much deeper stove. Which also could be an issue with the damper handle operation, as it sits on the back left side of the stove, which might be recessed a little into the fireplace box. It's hard to tell.
Then we saw a Hearthstone Craftsbury this weekend. And I really like this stove. It seems easier to operate, and the soapstone seems appealing to me. (It's lined with soapstone, though having cast iron on the exterior). However, My concern with this stove is the firebox size. its .5 Cu. Ft. smaller than the Dauntless, even though it boasts longer burn times. We like, however, that this stove fits PERFECTLY on our hearth, with no modifications. It will sit almost flush with the face of the fireplace stonework. Also our (my) concern is that this stove will not keep up when the temps hit single digits or colder. Its "rated' for up to 1400 sq ft. heating at 40,000 BTUs. Given that the area we are wanting to heat is 1200 sqft, will it do the job?
I have looked online at the woodstock stoves. However, we really don't like the idea of ordering a stove sight-unseen. And I have concerns about their stoves fitting our fireplace needs.
I apologize for the lengthy post. I've been researching, measuring, calling, and emailing for a few weeks now. I'm to the point my brain is going in circles trying to make this decision. ANY input and help would be appreciated.
Pic of our fireplace attached for reference
(For those that are wondering, we are having the chimney liner repaired. The inspector noticed that some of the connecting rivets have been broken, or as he said it: were not installed correctly. The chimney fire also damaged the connector tee and the first few feet of chimney pipe, according to the inspector. He said it was damaged because of the stainless steel tee being discolored. which I've read mixed things about._)
![VC Dauntless Vs. Hearthstone Craftsbury for small fireplace/hearth (HELP) VC Dauntless Vs. Hearthstone Craftsbury for small fireplace/hearth (HELP)](https://www.hearth.com/talk/data/attachments/272/272707-05d21a529e21787609bd49e41493dfa0.jpg)
Firebox: 28 7/8" H
