I was just givin a 0041 resolute acclaim. it was used sparingly. I see no refractory panel on either side or on the fire back. It was casted in 1995. can anyone tell me if if required them on the parts blow up diagram.
This stove has a fireback assembly in the rear that protects the fragile refractory combustion assembly. No side refractory panels, instead it has side shoulder plates with insulation behind them. https://www.woodmanspartsplus.com/68/details/9720/Resolute-Acclaim-0041/10155.html
FWIW, this was not a great stove. It needed frequent replacement of the combustion package if one was burning 24/7.
I haven't heard of many issues with them. The main problems usually were with the refractory breaking apart and the fireback cracking. Installing them shouldn't harm anything though they will be vulnerable to cracking from logs hitting them.
thanks for your input! I just finished the fabrication and they installed nice and tight. the combustion pack is like new so ill take it easy on high temps.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
