Gooserider said:Unless you have a vac that is rated for use on fires, do NOT use it on ashes unless you KNOW they are stone cold totally dead - like out for at least a week... An ember can stay lit for an incredibly long time in a bed of ashes, and if you suck it up, that paper filter makes a really great tinder to turn your vaccum into an impromptu flame thrower...
Remember that the vaccum moves an awful lot of air through it, and what you do to get a stubborn fire going - like blow on it....
If you search the threads, you will find multiple first person oops tales... Note that most modern vacs are made of plastic, which is VERY hard to put out once it gets going good. This is one of those actions that falls in the "high risk / low brains" category, sometimes associated with the Darwin Awards.
Gooserider
Tfin said:The only time I use my shop vac is at the end of the season when I'm cleaning out all the cold ash.
Other wise its a stove shovel and metal pail for me.
myzamboni said:Tfin said:The only time I use my shop vac is at the end of the season when I'm cleaning out all the cold ash.
and a a wet sock on the outlet to prevent any errant ash from getting blown into the room. A white sock turned grey is all I needed to see as proof that it works.
