Is the dash in between HR and number Blinking circled in green in pic? Do you have stove hooked to external thermostat? If not is thermostat Jumper in place? Sounds like stove is staying on idle and not ramping up to selected heat settings. If hooked up to external thermostat is it calling for heat?
After checking on above. check C Codes to see if feed settings are correct. Especially C-2 and C-3.
Be aware it can take up to 20 minutes to fully go from one heat range setting to the selected setting but you should start to notice difference within a couple of minutes.
6039 4 Digit Board C Codes
To adjust the operation constants, press the hold the MODE and AUGER DELAY buttons
simultaneously for 3 seconds. The display will show “C-1”. Use the HEAT RANGE UP or HEAT
RANGE DOWN buttons to change the constant number (see the list of vales below). When the
desired constant is displayed, press the ON button to toggle between viewing and editing the value.
While editing a parameter, use the AUX again to return to the constant number list. Press the OFF
button to exit the operational constants mode.
C-1- Reset to defaults (hold mode and auger delay buttons for 3 seconds to reset all to
defaults)
C-2- Fuel Lbs. Per hour HR 1 (0-6.5) - this is the fuel rate in pounds per hour for a heat
range setting of 1. The Default is 2.0lbs per hour.
C-3- Fuel Lbs. Per Hour HR 9 (0- 6.5) - This is the fuel rate in pounds per hour for a heat
range setting of 9. The Default is 5.0lbs per hour. The fuel rates used between settings of 1
and 9 are linearly interpolated between the two settings.
C-4-Agitator On Percentage HR1 (0-50) – this is the percent on time for the agitator for
setting of 1. The Default is 25%.
C_5-Agitator On Percentage HR9 (0-50) – This is the percent on time for the agitator for a
setting of 9. The Default is 50%. The percent on time for the agitator used between
settings 1 and 9 are linearly interpolated between the two settings.
C-6-Room Fan Level HR 1 (0-500) – This is the output level applied to the room fan for a
setting of 1. The Default value is 250/500.
C-7-Room Fan Level HR 9 (0-500) – This is the output level applied to the room fan for a
setting of 9. The Default value is 370/500. The Room fan output levels used between
settings 1 and 9 is linearly interpolated between these two settings.
C-8-Draft Fan Level HR 1 (0-500) – This is the draft fan output lever for a draft fan setting of
1. The Default is 230/500.
C-9-Draft Fan Level HR 9 (0-500) – This is the draft fan output lever for a draft fan setting of
9. The Default is 270/500.
C-10-Draft Fan Full On at Setting 9 (0-1) – If this parameter is set to 1 (default), the setting
for C9 is used for a fan speed of 8, and a value of 500 is used for a fan speed of 9. If the
parameter is set to 0, the setting for C9 is used for a fan speed of 9, and all remaining fan
speeds are set based on the interpolation between C9 and C8.
C-11- Ramp Seconds for Increasing Level (0-300) – When the heat range setting is adjusted,
the control will ramp from the current setting to the target setting to avoid abrupt changes
in the outputs that could cause problems with the flame quality. The Ramp Seconds value
sets the amount of time to spend on each heat range setting as the current setting is
ramping toward the target. If the current setting is ramping down toward a lower target, the
ramp value is half the number. The default value is 90 seconds.
C-12-Startup Minutes for Detection Warm Stove- (10-60) This is the amount of time the
control will wait for the stove to reach the warm temperature (110°F) after the stove has
been started before shutting down and reporting an Error Condition Err3. The default is
30 minutes.
View attachment 325770View attachment 325772View attachment 325773
