Hey guys,
I’ve been having some issues with my USSC / King pellet stove / Ashley AP60 ( they are all the same thing correct? )
Anyways, it just recently started tripping the high limit switch. ( or at least I believe that’s what it is )
The switch is located on the left side of the stove, just under the hopper. Has 2 connections and a red reset button in the center.
Stove will fire up, everything sounds normal. Then maybe 3-4 minutes in, the auger will stop feeding and the fire will almost instantly go from a nice strong flame into a smolder.
So I figured maybe it was dirty m? So I just deep cleaned this stove, AND the flu.
( I took it outside, took a leaf blower and blew out the exhaust ports, the hopper, inside the stove its self. I did this for about 10 minutes until no more ash / dust / etc was coming out ) the stove seemed spotless.
It’s still tripping the high limit switch ( or at least that’s what I think is tripping )
What else could cause this? What are other things I should look at? I was debating on bypassing the limit switch to see if it runs as normal but wanted to post on here and get opinions.
Thanks a ton.
Thanks a ton.
