One year ago I got a used USSC 6041HF (2009 model year) that has been sitting in my basement not used till yesterday evening. It may not be recommended, due to draft fan being smaller than some units, to do so but it is venting into a unused chimney that has a really good natural draft. I have a fresh air supply to it and the plug under burn pot is out as well as the two holes behind fake fire brick are plugged with electric breaker box knockout plugs, DRAFT IS OF LITTLE TO ZERO CONCERN AT THIS TIME. I removed the panels, the fake fire brick, the burn pot, the draft fan, etc. etc. etc. and cleaned the unit thoroughly the other day so I know for sure the unit is very clean and also put in a new door gasket. As far as the unit producing good heat and a good flame and room fan circulating air it has proven itself very well at least for the 5 hours it burned last night. I have a USSC 8500 on season four tuned in rather well keeping 2700sqft warm so I'm familiar( at least familiar enough to be dangerous) with pellet stoves. Now my 6041 has an igniter that does not work but I'm okay with that for know cause I can light it easy enough with a few drops of burn gel. For next season or maybe even sooner than later I will likely get the igniter working but like I said, without it for now, I'm okay without it. My question is on the startup cycle it has three pellet lighting phases where during phase one it runs pellet feed auger at 100% duty cycle than in phases two and three, of startup cycle, is reduces the duty cycle each time. Supposing it does this first to allow igniter to get hot than putting a bed of new pellets on it to light is how the process works, it's really neat how it does it. Now since my igniter is no good at the moment is there a way to stop the 100% duty cycle during startup, phase 1, to 0% so that it don't snuff out the fire I started with the gel? I stopped it by unplugging pellet feed auger until it had a good flame than once plugged back in it took of without any hiccups. The C16 setting, pellet lighting phase one period, is for three minutes so if I take that to zero and will it stop that 100% duty cycle during phase one or is that three minute phase something that can't be altered? Let me know. Thanks
