Hello all,
First off I'm a newbie to the site, I've been lurking a while and reading what I can find now I'm having issues i can't find information on so I'm looking for help.
I bought my 6039 as a non working unit as the seller claimed. I got it home, set it up and it works, well kind of. I have the 3 button control board. The first couple times I tried to use it i had no room fan, then the 3rd time the room fan come on as soon as I plugged the stove in, so I lit it and it ran great for 24 hours. After that it shut itself off, I turned it back on and it was good, I went to turn it up and as soon as I touched the key pad it shut off again. I slapped the side of the stove and it turned back on, an ran great for 12 more hours. I'm guessing this is why the guy got rid of it. I bought a brand new board, 4 button from USSC, part # 80507, I shut the power off and unplugged the stove. Waited about 8 hours, took it apart, put the new board in. Issue1. When I started it, the draft fan comes on and shuts right off, if I open the door it comes back on, when I shut the door it stops, not sure what that's about. Issue 2 , after trying several times to get it going it gave me an error code 9. I did the manual reset, holding both aux buttons at the same time, it said bye and reset. But still will not turn on the draft fan unless the door is open.
What am I missing? I'm guessing it's something simple, I put the 3 button board back in and it works just fine, but who knows when it will shut itself off an I'm not wanting to wake up to a cold house.
I'm not using any kind of thermostat, the only wires to hook up are the main plug and the bc1 an bc2,(the new board has bc2 an bc3) i tried hooking then up both ways an it made no difference. I do have the draft in the bottom below the fire pot,I donot have a oak kit, house is definitely not air tight, I have 3 inch dbl wall pipe going up 9 feet. I cleaned every nook and cranny on this thing when I brought it home. I replaced the agitator motor and fire brick, it works great until it shuts down. I bought the new board to fix that issue and have more control, just need help with the hook up on it. I do burn hardwood pellets. Any help/ ideas would be greatly appreciated.
Thank you!
Thank you!
