Stove runs fine on all other settings, but when running the heat range on 5, the stove will run for about an hour then the draft fan shuts down. In turn shuts the stove off. Is this what happens in an over fire situation on these stoves?
Thanks Smokey! The stove will run fine all day on the highest settings, its has the problems in the morning when the thermostat ramps up from 68 to 72. Could see restricted exhaust causing it but cleaned stove and exhaust pipes thoroughly and still shuts the draft fan down after about an hour on high. Maybe it cant run on high but why put that unusable option there lol!
I never ran mine on HR-5 for more than a short period of time. Depending on what pellets you're burning that thing would put out A LOT of heat running on 5 for an hour or more. Must be a pretty big area you're heating. Did you take the room blower off auto and put it on 9 by chance?
