So we all know that the stone lags the cat temp quite a bit and it seems using the single wall pipe as a guide is better so you can engage faster, but for those of us with double wall, might lifting the center stone and using the griddle below as the guide be a good idea?
What I'm thinking is that if I'm doing a cold start then just lift the center stone and fire up until the IR thermometer pointed at center of griddle hits xxx degrees and engage cat, then lower the stone and be done with it.
Has anyone tried this and if so, what temperature have you found works well?
