I have a relatively new water heater that we are no longer using and I'm curious if there's any reason why it could not be used to add a little capacity to my boiler system?
It has an anode rod in it that is in fairly good shape and the biggest question I have is if it will cause issues with the "control" product that is in the water to stop corrosion in my boiler system.
I would plumb the tank in on the return side coming from my farm shop as the return temps are sometimes below 140° f and this would hopefully help temper it a bit before it goes to the wood stove.
I have seen threads on here about using all kinds of different things as thermal storage tanks and I'm wondering if anyone has done it with a water heater and if the anode rod should be left in or removed.
Thank you in advance for any advice!
