Great video thanks for taking the time filming and posting it.I made a brief video so you can see how I do it:
6 inch flue might not create enough vacuum to suck anything out. Pellet stoves make alot of ash that sets in the horizontal vent pipe. Most wood stoves have a more vertical path.Do you think this would work for a woodstove flue?
Copy that.Bad idea, there’s been a few try it and have covered the inside of their house with dust and soot not to mention irate wives
Some leaf blowers come with a vacuum/leaf shredder some do not. You can modify a non vacuum/leaf shredder one to work by siliconing pvc adaper on to it. But it is much easier to get one with the vacuum/leaf shredder most times you can just stick the vacuum tube right onto your vent and it will work, some get a rubber pipe adapter for a tighter fit the size of the rubber adapter would depend on the size of your vent and the size of the vacuum/leaf shredder tube. You want to have both the vacuum tube and the blower tube on because with the blower tube on it pushes the ash further away from you. You might also want to check the wind direction, lol. Gas powered leaf blower would also work especially if they have the vacuum function. I usually do mine twice a year, at the end of the heating season, and sometime in January when stove starts to run poorer because vent pipe is getting plugged.
Probably 3 to 4 foot of pipe, I can take the portion of the pipe that goes up off
I do have that toro but at my Utah place. Will get one here in Nj and give this a try. ThanksYour best bet is to get ahold of a Toro, they have a powerful vacuum and attach it to the top of your exhaust and letter rip, use an air compressor on the firebox and your stove will run like new
... If I wanted to give it a try, for no other reason than to make a big cloud of dust. ...
