Ill be looking at a used Regency F3100.this weekend (asking $600 ) Is there anything I should be on the lookout for? Just from the pictures it looks to be clean,he says its 100% and all the bricks are good.
Check the back corners in the top for cracking in the secondary air manifold. And in the front inside above the door for cracking or distortion. If it is just the air deflector there that is no big deal to replace. If it is the air channel itself that's a problem
Thats just the kind of info I need.Thank you
Last year was my first Real wood stove (Kent tile fire) works good,but need bigger
(30wx60l X13 h) Pole Barn(semi insulated)
I just saw this up by the top right corner,,,Next to Reporting ...I think it says,,,May 93? Is that the year manufactured??If so,isn't that a bit old to be buying even if it is in good condition?
Sorry,not trying to be a PITA just trying to get it right
would the cracking in the secondary manifold be what the air tubes connect to in pic #36-37? Or the baffle set above it #37
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
