So I finally found a good deal on a log splitter. I spotted a reduced price 30 ton Countyline at the local TSC the other week. Inquired about it and was told that it was a return from an unhappy customer, and it had a small oil leak. They were asking 1300 (regular 1500). I researched it and decided to try and get a little better deal. Talked to the manager and he gave me a coupon for an additional 100 bucks. It's supposed to even still be under warranty. 1,199 plus tax, including fluids and half tank gas. The sticker on the beam was scuffed but still legible so you know it was not used much.
Got it home and used it for about 30 minutes splitting some red elm. It really works good. 10.5 seconds is fast compared to the 3pt splitter I'm used to. Definitely has good power.
The hydraulic pump leaks a little, mainly at the end of the return detent cycle. After 30 minutes I had maybe a 10-12 oz of fluid. It appears to be leaking from the input shaft seal. Should be an easy fix I'm assuming?!["Used" countyline 30T splitter leak "Used" countyline 30T splitter leak](https://www.hearth.com/talk/data/attachments/261/261306-85c60850823365e90b4af2d8733303e9.jpg)
