I have an old house from approximately year 1850. The main brick portion of this house has a large living room with two fireplaces (one on each end of the room).
The small fireplace in that room was ruined by a clown (certified chimney guy) as detailed in my previous post. I salvaged the situation by getting a small Jotul 3 TDIC-2 stove. It is really insufficient in the cold winter... but I think I will really appreciate it in the shoulder seasons. It is functioning as a supplemental heat source currently and working well.
The opposite end of this room has a large old Rumford fireplace in a completely unlined large old masonry chimney. It is obviously not to modern code, but seems to have quite good draft, and I have been tempted to fire it up, but for the fact that it is really covered in debris. I had wanted to have it lined with cement in order to preserve the original size and anatomy of it (it is a good design)... however it is difficult to find competent people to perform this work and at a fair price and to actually come out and do it.
If there ever were ANY fireplace to keep with the expectation of getting at least some amount of heat from it and not only ambiance, this would be it. That being said, I have acquired an old Woodstock Fireview “Belly Baffle”, which Woodstock has informed me is an obscure early model made only briefly. I have ordered the complete baffle kit which will essentially convert it into a Fireview 201 model. My expectation is that this will give a large amount of slow prolonged heat, as opposed to the small amount of quick and very radiant heat that I am getting from the Jotul.
This old unlined chimney is adjacent to brick walls of house on one side, and plaster directly on it on the interior. So I was again really tempted to just put some black stove pipe up the length of it and run it for now. It is accessible, and no problem for me to constantly inspect it and replace as needed. Of course, I read the hearth.com threads on that issue, and I know it “should” (for unclear definitive reasons other than longevity / corrosion resistance) have a proper liner so I was planning to buy rigid stainless steel liner.
Then of course, I am down the rabbit hole of “do I really need to insulate it”, and while I do think it would “work” fine without it, it seems that performance can only be increased by insulating it.
Due to the way I am installing it (from bottom up through the fireplace), it will be in 3 foot sections. I have not found good information on preferred method of insulating rigid liner. The rolls of insulation, glue, tape and netting that seem so appropriate for a flex liner seem to be thoroughly inconvenient for rigid liner. Especially since it has to install 3 feet at a time. I am estimating 18 feet total liner.
There is snap together rigid liner insulation (steel layer with pre-attached insulation) costing $33 for two foot sections. Three foot sections of rigid liner cost $67. So total will be (33 x 9) + (67 x 6) = $699 total.
Meanwhile I see Selkirk Sure-Temp double wall class A chimney pipe that would cost only $678 for the same total length. It is stainless steel on both layers and looks really nice. It can stand alone, and what a shame/waste to put it inside a chimney. I am going from completely insufficient in the eyes of hearth.com (uninsulated black pipe) to complete overkill (Class A bestos pipe). But as you see, it is roughly the same price, and even a few dollars cheaper.
- Is there any reason not to put the class A chimney pipe in??
- Is there some more reasonably priced alternative for insulation on rigid chimney liner??
Thank you very much for input on this matter.
